TwinTurbo.NET: Nissan 300ZX forum - Re: Syn. 10W-30 oil change, now rough idle and blue smoke
MaxxAction
on August 30, 2012 at 3:39 PM
posted by Mikester(Seattle)
on August 30, 2012 at 12:15 PM
I would check to make sure they didn't overfill it by a quart. If you got any leaks, overfilling the crank case will make it leak like mad.
Mikester(Seattle)
12:15:23 08/30/12
Note: Ticking was due to being very low on oil. (n/m)
Mikester(Seattle)
12:25:28 08/30/12
Re: Syn. 10W-30 oil change, now rough idle and blue smoke -
MaxxAction
15:39:18 08/30/12
After work, I tried starting and it gave an abrupt *thud*..
Mikester(Seattle)
20:30:28 08/30/12
Consult says Code 11 - Camshaft Angle Sensor Error
Mikester(Seattle)
20:54:12 08/30/12
Well, if you have CAS error I would check the wiring and
JonnyZ(SoCal)
00:03:26 08/31/12
MaxxAction
08:55:40 08/31/12
pull the plugs and see if it spins over. (n/m)
Gordo 93TT Daytona
16:35:45 08/31/12
